Annoying pop up on every login on Arlo app
Every time I login to the app, it keeps popping up with "keep me updated with latest news support from Arlo"
Doesn't matter what I press, or update settings with no update.
I keep getting this popup!
Please how do I get rid of this popup, shows up the second I try to log in
Have you rebooted your phone and reinstalled the app?
Still not worked, uninstalled it, popup still appears
iOS or Android? What phone and OS? is everything updated, app and OS? Try force closing the app andclear cache and data, then reboot the phone.
Nothing you can do on your end. It's Arlo's cpe sending message. They want you to buy.
