Secondary PIN's not working
Anyone else having issues with Secondary PIN's not working?
I've opened a case with Arlo Support, but not getting any clear answers.
Yesterday, contractor working on my vacation house set off the alarm. His PIN did not work. Nor did another PIN. I had to disable the alarm. These PINs had been previously been working as soon as last week.
I have a paid subscription to Arlo Secure. If I go to Settings, click my location, click PINs, confirm my password again, I get a page that says at the top:
Secondary Security PINs and Duress PIN are disabled.
Subscribers can enable multiple PINs and silent Emergency Response.
And then lists all the secondary PINs that are not working, greyed out, with no ability to add/modify/delete these secondary PINs.
Case #43517458 if anyone at Arlo is watching.
Keypad Sensor Hub
PIN
Secondary PIN
MikeInTahoe,
When you first installed your system, it included a trial to the Arlo Safe & Secure Pro plan. To utilize secondary PINs you need a subscription to an Arlo Safe & Secure Pro subscription plan, the Arlo Secure plan does not include this feature.
For more information on this, see here: https://kb.arlo.com/000063002/How-do-I-create-modify-or-delete-a-Secondary-PIN-for-my-Arlo-Home-Secu...
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
