Feeling like an idiot! I do not see this gray line for the siren button on the new update!!
Hi everyone,
I wanted to update everyone that you can now trigger the alarm for Arlo Go.
You can do this by going to "Devices" tab and pull down the gray bar (below Arlo) and choose "Alarm." Once you choose "Alarm," you will see the following screen shown below. After hitting "Yes", this will trigger the alarm; however, if you have more than one product that can trigger the alarm (Arlo Go or Base Station Pro), you will get the next pop-up screen asking which product you like to trigger the alarm.
Hey @Bewright,
Do know that this is only available if you have the Arlo Pro Base Station set up.
When opening the app, you will see the gray bar located below the "Arlo" logo which is near the top (located on the main screen on "Devices"). You can drag it down and you should see the "Siren" button.
Which device are you using to view the live view from your Arlo Go? And what app version are you running? There should be a bell icon, which triggers the alarm on or off from the Arlo Go. If you are unable to locate the bell icon, try to see if you can see it through the web client.
The app has nothing to do with the recording. If it isn't in color, the light threshold has been tripped from day to night. Move the camera temporarily to prove this. Post a screenshot for suggestions.
I’ve been using this camera for almost a year
Rescuing dogs I never had one single issue with color ever. As soon as I get the new update problems arrived instantly.
Night vision at night after 10 seconds of recording at night.
Is obvious that the day and night sensor
In the app not the camera is the issue
I have two cameras and both do the same
On off auto options
Hey everyone,
Our development team is aware about the the issue where some users are not able to see the siren button on Arlo Go and is currently investigating the problem. We appreciate your patience and understanding about this and will provide any update as soon as we have more information to share.
In iOS, it has been moved to a small pull down tab , top center of device screen
Has there been any further news on the alarm. There is not pull down option on my screen. No alarm ability after the update. They should send email to owners if there are issues.
Post a screenshot of your Devices tab. Have you reinstalled the app?
ArloGo: I'm operating an ArloGo on my cottage and used to have the "Bell" to warn intruders "live" to get off property. It's gone now on 2 different phones. It would be great to know where it went to and to get it back. The bell however is still there when I sign in on my laptop through the internet
The gray stripe/pull down drawer near the top of the Devices tab has been the method for turning on the siren for some time now.
I understand that I can "leave" the live picture, and go in to settings and turn on the alarm. But that requires me to leave the LIVE picture. I'd prefer to have it back the way that it was before. You could watch and hear the alarm go on. Then, you can see how the people on your property react. Arlo Admin simply needs to restore what was there, because it was better and easier. Just because you have the ability to change something doesn't mean that you should
I have an Arlo Go and Arlo Pro 2, both on the Arlo app on my iPhone. The gray line at the top of the screen on my iPhone triggers the alarm on my Arlo Pro 2 base station. The bell that triggers the built in alarm on my Arlo Go disappeared with a recent update so I am unable to trigger it. Where is it, when is it going to be put back into the app?
I still can’t believe Arlo hasn’t fixed this, I have 4arlo go cams at a property and can’t trigger alarm. I am going to look at replacing them with the REOLINK GO. Looks to be a good alternative as it’s cellular, has solar panel, YOU CAN TRIGGER ALARM!, and the camera is less expensive. https://m.reolink.com/product/reolink-go/
Im pretty frustraded too! Such a simple thing that Arlo seems to not give a damn about. I too was going to add more to my job sites, but with such bad customer follow up I am done with Arlo!!!! They had a very happy customer until this!!!!
ARE YOU EVEN LISTENING ARLO??????
They threw up the button on the pull down but it serves no purpose since it doesn’t function.
Modes et règles
