- English
- Cameras
- Re: My Arlo essential spotlight camera (VMC2030B) ...
After charging my camera, it will no longer connect. It flashes the blue light several times before showing amber. I tried the online advice and removed and reconnected. It will not acknowledge the QR code. the blue light will blink until the battery goes dead. This camera is just under a year old.
It can be a bit fussy - making you shift the QR code around in the field of view.
Have you tried using a PC (my.arlo.com) instead of the phone? Also, make sure you select the essential spotlight (and not the essential).
Still under warranty, so I suggest contacting support quickly if you can't get it connected.
I am having the same issue...flashes quicky, slowly, solid, quick amber repeat and no connection. I have tried to reset the camera by holding sync until amber light (nothing, never get the light). Never connects...
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
