- English
- Cameras
- Re: Can you use a Arlo Essential Outdoor Spotlight...
Hello there,
I currently have three Arlo Pro 3 Cameras on my system. I want to add a 4th camera in my house, and don't need anything fancy and was wondering if I can add an Essential Camera and have it work with my base station and existing app with the three Arlo Pro Cameras.
Hi @DMOA
The Arlo Essential cameras are compatible with the following Base station/Smart Hubs: VMB4500, 4000, 4540, 5000. You can fond more info here: What is the difference between each Arlo SmartHub and base station?
You can also connect the essential series cameras directly to your router if you like. You can find more info here: How do I connect my Arlo device directly to my WiFi router if the camera is currently connected to a...
Hi @DMOA
Thank you Shayne!
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
