I selected a group of videos to delete and deleted them. Or so I thought. When I looked the videos are still there. When I select the group again, the lower left display verbiage says videos selected. Unfortunately, the Delete symbol doesn’t highlight, and doesn’t delete the videos. Do I have ghosts?!
App or web client? If app, which one? Have you tried both?
It’s an app on my iPad. Thanks for the quick response.
You didn't answer whether you had tried the web client (my.arlo.com). I don't have iOS devices so can't comment on whether that's a bug or just an issue with you. Do you have any other iOS devices (phone, etc.) that you can try?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
