purchased the Arlo wired video doorbell, connected to wifi, and it does not work. instructions followed by contractor, YouTube installation instruction followed & still not working. YouTube instructions said nothing about charging a battery.
there was no battery or charge cable in the box. please advise.
Why you are bringing up the battery?
There is a small internal battery that can handle short power glitches. The transformer you are using should be able to charge it. It should charge in just a few minutes, so it is unlikely to be your problem.
Does the doorbell not work at all? (not ringing the chime when pressed, not able to livestream, ...)
Did it ever work?
Hi StephenB,
@fw83437 wrote:
The Arlo did not light-up after installation (per a youtube video we watched), the ring circle did not light-up, and didn't light-up when pressed, there is no livestream.
And I'm guessing that the chime doesn't ring when you press the Arlo doorbell either.
Have you tried the factory reset?
Also, does your doorbell have an AVD1001 label somewhere? Or does it have a different AVDxxxx label?
correct, the chime does not ring. I did not see a "remove" button and could no scroll down.
so I deleted the app and reinstalled it. went through the set-up steps again and still problem at the
"did the light on the front of your Arlo doorbell turn solid white" answer is no. no white light and no lighted circle.
-- Arlo does not seem to connect to my Verizon Fios.
will try again in the morning.
Are you still seeing this behavior?
