Best answers
Have you tried a RESET of the camera? Try it and then bring back as if new with app.
To factory reset your Arlo Essential Indoor Camera:
Press and hold the sync button on the camera for about 15 seconds. Ensure that the camera LED rapidly blinks blue after you held down sync button. After a factory reset, the camera still appears on the Arlo app, but it is disabled
If it won't turn on, have you considered the possibility of a failed power adapter? WHen plugged in initially you should see the LED flash briefly - do you?
If you saw the rapid blue flash, that implies it was found. I've had this scenario happen in the past - try to connect a camera, it seems to happen but nothing shows up in the app as a new device. I then force close the app and re--open it and, voila!, it's there. Not saying this will work for you but it's worth a try.
I had a power outage recently. All my cameras, one Arlo Essential indoor camera, three Arlo outdoor cameras and an Arlo doorbell went offline. When the power came on, everything except the indoor camera came back online. This indoor camera by the way is the closest to the Wi-Fi router in my house. The other devices are further away since they are outside.
So now I am having the exact same problem as the person that I am replying to. I did everything specified in that person’s original post and the replies. NOTHING HAS WORKED. Any suggestions other than throwing the camera in the trash?
Is the indoor camera paired with a base, or is it connected directly to your home wifi?
If power-cycling the camera didn't resolve it, you might need to try this: https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
The reset itself is accomplished by while the camera is powered on, press and hold the sync button for about 15 seconds, until the camera LED begins blinking blue, then let go. (page 54 here: https://www.arlo.com/en-us/images/documents/arloessential/Arlo_Essential_Indoor_UM_US_1.pdf)
Hi Stephen, I have wi-fi connectivity. I also tried the factory reset but it didn’t work.
Did the camera recognize the QR code?
Yes it did.
Hello, just out of curiosity, did you ever get your indoor camera back online and if so, how did you make that happen. Thanks.
