I get notifications and they wont go away. I click on the notifications and it does nothing. Pressing clear wont remobe it either. Happens on door bell and call from door bell
I find they automatically go away after 10-15 minutes (haven't actually timed it).
I am using Andriod phone with Android Pie OS. I have the exactly same issue which is really annoying. I had to turn off and or notification for Arlo to make it goes away. However, it suddenly comes again sometime later... Arlo, please fix this issue ASAP
You can swipe right on this notification, tap the gear icon and minimize the notification. This will clear it from the pull down drawer.
Hi JamesC,
Thanks for your reply. Actually, it doesn't go away by swiping right. If I minimize it, it comes back later soon. Restarting the device or accepting another doorbell call can get rid of it. That's really annoying me.
I'm having the same issue. You can't swipe it away, disabling notifications will clear it teporarily, but it will come back and stay for good after. In addition I get duplicate notifications for EVERYTHING..... image is attached
I'm Using:
Android 8.0.0
Kernel 4.8.78-15104940
Build R16NW.G955USQU5CSA4
Arlo App Ver: 2.7.1_23406
Hi @Ruffiano
Have you tried to remove & reinstall the Arlo Mobile App and test again.
You can also clear the app cache and test again. You can do this by going to Settings > Storage (device care) > Storage > Apps > Arlo > Storage > Clear Cache
I'll give that a try. I was relunctant to do so as I've heard that reinstalling the app was the cause of the multiple notifications, and each time you do it, you'll just add to the number of notifications. We'll see if that is the case.
You may also try contacting customer support regarding this issue before doing so? I have attached the link here for you - Arlo Tech Support
I'll contacat support, as I thought, I am not getting 3 notifications for the same event.......
