vmb3500 installation instructions
I have had this system for a couple of years but never installed it. Can you send me the directions?
janie1,
You will first need to download and install the Arlo mobile app from the app store on your mobile device. After installing the app and setting up an Arlo account, log in to your account and tap "Add new device". Select the desired device and follow the on-screen instructions.
