Will Ultra cameras integrate with Google and Nest Max Hub?
  • 1 Reply
  • 1227 Views
ronsmithrea
I have the Ultra cameras. Will they integrate with Google and Next Max Hub? if there is activity can the max hub be set so that the activity will auto pop up.
JessicaP
Hi ronsmithrea,
The Arlo Ultra cameras will work with the Google Assistant app. You can use the Google Assistant to show your live stream. You can read more about it here:
