- English
- Arlo Forum Discussions
- Partner Integrations
- Will Ultra cameras integrate with Google and Nest ...
Will Ultra cameras integrate with Google and Nest Max Hub?
I have the Ultra cameras. Will they integrate with Google and Next Max Hub? if there is activity can the max hub be set so that the activity will auto pop up.
Hi ronsmithrea,
The Arlo Ultra cameras will work with the Google Assistant app. You can use the Google Assistant to show your live stream. You can read more about it here:
AppleTV
32 -
Samsung SmartThings
84 -
Security System
