spatel9114
I’ve set up my VMB4000 Base station with 1 Arlo Pro camera and 3 Arlo Essential cameras, and when I try and configure HomeKit on the base station, it gets stuck on the discovering step and won’t actually connect. Can I get some help?
783 REPLIES 783
brad54534
GLBCGA
Same problem here, too.  Please send the token. Thx.
Tina3505
I’m having the same issue if you could help me as well
Lrepass
Hi, I am having the same issue and gave up some time ago. Now I’m reading that Arlo can just send a new token to my Basestation to fix the problem? That’d be great. Can someone help me?
MPopt
I know it's one year later but can you do the same for me, I get the uncertified accessory error when adding to HomeKit
fgomecs, regieromo, Flufdk, brad54534, GLBCGA, Tina3505, Lrepass
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Lrepass
That worked perfectly. Thank you so much.
fgomecs
It didn’t work. Do you mind resending the token?
fgomecs,
miked4
Can you send the token reset request to my base station too please?
miked4,
rtg888
Hi,
I am having the same issue with the same model base station.
Can you please also send me the reset token?
Thank you so much!
Perrybal
Home kit integration fails with uncertified accessory.
Please send me the token
rtg888, Perrybal
Kalm
Hi there, I have this exact same issue with the VMB4000R3 base station. If you could please help with the token send?
Many thanks!
Gerry
Kalm,
Mediummike
I need the reset token, too. Is this really the best way to solve this problem?
Mediummike,
Mediummike
Thank you. Working perfectly now.
Retired_Member
Not applicable
Hello
I got a 4 camera Ultra 2 kit from Costco. Despite multiple reboots still getting “accessory not certified” message.
Please advise.
Thank you
Shini03,
geekandi
Could I get a token sent as well?
This is pretty frustrating. Also created a support case as #42033973
geekandi,
mjulier
token, please
mjulier,
