Unable to add accessory HomeKit
My base updated and since I am had issue with HomeKit. I try to delete and reinstall and now it says Unable to add accessory.
from what I see can you reset my Token? Arlo Pro
Thank you
Hello,
can you help me resetting the token.
It works then suddenly disappear from HK again
It is stuck on Discovering your device please wait.
I will give it one more try
Thank you
it was working and then left again... Thank you for your help
Josh92971,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
