- English
- Arlo Forum Discussions
- Partner Integrations
- Start recording on "arlo wire-free" when motion de...
Just happend to know that "arlo wire-free cameras" work with "Samsung SmartThings". Is it possible to Start recording on "arlo wire-free" when motion detected on "Samsung SmartThings Motion Sensor" ?
This setup really helps as I want to place a camera at end of hallway and install a motion sensonr beginning of hallway. so that it will start capturing video as soon as some one enter hallway.
@iosman123 wrote:
Just happend to know that "arlo wire-free cameras" work with "Samsung SmartThings". Is it possible to Start recording on "arlo wire-free" when motion detected on "Samsung SmartThings Motion Sensor" ? California air tools 10020c
thanks my issue has been fixed,, thanks
Yes you can. In Smartthings you can create a custom rule, (in the Classic app - an automation in the newer app), so that when the Smartthings motion senses motion it will trigger the camera to record). I do this a lot. If you need help with this let me know.
Brian
AppleTV
32 -
Samsung SmartThings
84 -
Security System
