Smart hub and Homekit connection issue
  • 1 Reply
  • 1843 Views
json004
Hi there
My smart hub (VMB4540) which is paired 2 cameras (Arlo 5s 2k) can not connect to Apple HomeKit.
So I rebooted my smart hub and I followed the instructions but it shows "HomeKit set up fail" I tried but same results. I rebooted my smart hub again but it does not work. I saw the some problems with HomeKit connections on community, someone has token reset to solve this problems. anyone can help to solve this?
thanks
json004
ShayneS
Hi @json004
The Pro 5s is not compatible with HomeKit at the moment. We are planning to introduce this feature in the future.
If you are having trouble adding your Arlo base station to Homekit, you can try the steps provided here; https://kb.arlo.com/000062279/How-do-I-connect-my-Arlo-device-to-Apple-HomeKit
