- English
- Arlo Forum Discussions
- Partner Integrations
- Request for reset token because HomeKit Set up is ...
Request for reset token because HomeKit Set up is stuck on “Discovering your device”
Please send to required token reset request to my Arlo base.
Thanks!
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions
I am having the same issue
I will reset the token again. Before setting up the Homekit, please uninstall then re-install the app and then reset the basestation/hub again and then follow the steps within the link.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
