Official Compatibility List for Arlo
  • 2 Replies
  • 10684 Views
guard999
I'm sure this must be somewhere...but I can't find it anywhere! When you go to the NEST website you'll find an official compatibility list that NEST keeps current. It's not something put together by the community, it's an official list of other products where there was some cooperation/tech sharing involved. I like the Arlo Pro cams but these really are just good wireless surveillance cams with some bells and whistles. There is no option for monitored service and if the property is large enough it'd be prohibitively expensive to stick cams at every possible egress. Some of the DIY security systems could really benefit from Arlo compatibility. Where can I find this list? Or perhaps it's really just a recommendation... Thanks
guard999,
Take a look toward the bottom of our website under "Our Partners": Arlo by NETGEAR
As more integrations take place, the list there will be updated to reflect current partnerships with Arlo.
I hope this helps,
guard999,
I hope this helps,
guard999
Thanks for comnecting me with that page James. I would ask/submit that you guys work on product integration with both Lutron (lighting) and Abode (security). I'm really trying to stay away from the monthly subscription of Nest Aware...but they have done the product integration part already. Thanks!
