Need Homekit Token Reset
  • 12 Replies
  • 11245 Views
  • 5 In Conversation
TimLSD
Hello I need a token reset to set up my homekit.
@Roche09 wrote:
@BrookeN  I tried to factory reset VMB4540, but found that Internet LED was alternating Blue and Amber when I pressed and hold the reset button for 10 seconds, which is different from the description 'the LED on the front of the Arlo SmartHub or Base Station flashes amber' in the article (https://kb.arlo.com/000062881/How-can-I-factory-reset-my-Arlo-SmartHub-or-Base-Station-Arlo-Secure-4...). Then the internet LED was back to solid blue. It seems that the VMB4540 refused to be factor reset.
Try not to double-post.
I replied here:
12 REPLIES 12
BrookeN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
https://kb.arlo.com/000063184
TimLSD
This did not work.
BrookeN
I can try to reset it again, before doing the steps log out of the account and log back in. And then do the steps to set up without a code.
TimLSD
I did all of the steps you mentioned. Still not working
BrookeN
You will need to reset the basestation. Please keep in mind that you will need to add the cameras again after the reset.
Roche09
Hi, can you send a token set request to my base station (VMB4540) as well? Thank you. The base station could not be discovered by Apple HomeKit for now.
BrookeN
@Roche09 under ther email address I am only seeing an Arlo Bridge. I do not see a VMB4540. Could it happen to be under a different email address?
Roche09
Hi @BrookeN thanks for the checking. It is a sad story. Arlo case #45563986 was initiated on 12 Apr 2026  to request a token reset for my SmartHub VMB4540, as it could not be discovered by Apple HomeKit. The SmartHub was then manually removed from my account as per the post (https://community.arlo.com/t5/Partner-Integrations/Need-Homekit-Token-Reset/td-p/2477295), however, the SmartHub could not be re-added to my account after factory reset. You can find the details in the following post (https://community.arlo.com/t5/Arlo-Pro-2/SmartHub-VMB4540-could-not-be-added-to-Arlo-account/td-p/24...). Appreciated if you could advise the trouble shooting steps accordingly.
BrookeN
Roche09
I replied here:
xRENEGADEgg
I also seem to be in need of a HomeKit token reset.
any help is appreciated!
