- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Integration of Arlo pro2 to Smarthings - Camer...
I had this working for a couple of years where I've integrated a driveway sensor to a open/close ST's sensor. When someone came down the driveway, it triggered the open/close sensor which in turn fired off a custom rule in ST to start 2 cameras recording for 1 minute. Worked great UNTIL 2 weeks ago. No changes were made by me. I don't know of ST or Arlo updated anything. I've restarted, rebuilt, deleted rules, added new rules, nothing. I can see in the ST app for the camera that a "sent Capture Command to porch camera" was sent. But the camera doesn't do anything. I've had it in disabled mode, ST mode, armed (on arlo). Was there an update from either company that might have screwed up this integration? I can manually trigger the camera in ST to record, but not by a rule. This really stinks because this was a great security feature. If I can't find a solution I'll have to rethink my whole setup. Thanks for any advice. I did search and went thru this thread just to make sure I didn't miss anyting.
https://community.arlo.com/t5/Arlo/Record-without-motion-Smartthings-Arlo/m-p/1531162#M50207
Okay, so the verdict is that both the 4500 and 4540 with Pro 2's are working fine with Smartthings integration. Others have already confirmed the VMB3500 and the VMB5000 hubs also work. So the only impacted hub as we kind of expected is the VMB4000. This is good because it clearly locks the issue down to that firmware on that hub. If this was a integration problem with Smartthings then the others would likely fail as well.
A potential work around right now would be to pick up the 2 camera kit from BB as it is fairly steeply discounted at the moment to $279. So 2 new cameras and a new hub that works with Smartthings. I admit that isn't a great option though.
I also validated this with a test smartthings app i have for Arlo. It uses the same method as SHM though
One interesting thing I found in this though is that the newer hubs don't seem to provide thumbnails of the video.
If you don't need the 2 new cameras then you could just get a the new VMB5000 smarthub that comes with the Ultras for also $150 instead.
I would suggest everyone here to go Arlo idea thread and comment about the need to improve the smartthings integration and inclusion of mode options with Smartthings.
Part of the issue here is that for whatever reason Arlo isn't upgrading the integration with the new smartthings model and as such are depending on very legacy methodology.
Ya know, now that Arlo has split from Netgear, I sure hope (and prey) that Samsung (SmartThings) is considing Arlo a prime target for acquisition!!! That way any integration like this should be in house.
However, I'm not sure at this point what the relationship between SmartThings and ANY camera manufacture will be since there is absolutely NO camera support in the new SmartThings Connect app's Home Monitor. See for yourself at the below link as you can toggle between both apps and see that video is not even referenced in the new apps Home Monitor features. The new app has been available for at least a year or so now and they still haven't put any camera support in there! Not even for their own Samsung security camera!
https://support.smartthings.com/hc/en-us/articles/205380154-SmartThings-Home-Monitor
Graeat idea, @Mistersandman ! I am doing the same. I think I found all of RobM's.
I get a call from arlo customer support 1 - 2 times a week lately updating me.   According to the last call Arlo engineering said they talked with smartthings and that smartthings is working on a fix.    I’m also getting a 5000 base on Monday.   I’m hoping to test it out to see if it works.     I thought one of you posted that it does.
ifanyone has a ST contact, maybe you could see if they are making a fix.
thanks all
I have installed the v5000 base station and have tested with one pro2 camera so far. It is allowing Smartthings to trigger the camera to record just like the good ole days. I’ll set up the rest tomorrow and should be back in business.
Just spoke to the local Arlo support and they just said, if it's workign outside ST we don't care..
Talking to Samsung support they told me to reset the ST hub which isn't an option. That would take me weeks to restore
everything.
Have anyone been successful in having Arlo support downgrading the hub?
Hope VB4000 is recalled due of not working, so Replace vb5000!
After LOTS of testing. I’m using the base station 5000. I have triggers working from ST to arlo and it is recording. I am running under the premium service of arlo BUT in my weekly call with arlo I reported:
- the ST trigger seems to work as long as you don’t use activity zones.   As soon as you turn on activity zones that camera will get the same commands from ST BUT the camera won’t record.   Hmmm sounds like a arlo bug 😳
Arlo eng said ST was working with arlo eng and that ST was working on a fix.   I asked Arlo support to have the level 3 eng dept at arlo to call me or pass my info on to ST eng to call me.   I need confirmation that a fix is coming for the v4000.     (Which makes no sense why ST has to fix it, but I’ll play along).
Here’s my advice, you might explore upgrade options with arlo since they broke the 4000 and the 5000 is working.   (But you didn’t hear that from me and please don’t mention me).   I’m sure you could also push for the 3500 as someone on here said that worked.   I have not tested that.   I’ll let you know any more updates.   I usually get a call from support 1-2 times a week.   Also if you do have the 4000 and by some miracle they do send out a fix, please let me know.    I no longer have a 4000 running.
happy thanksgiving!
Thanks so much Rob for your testing info on the 5000 hub and for the updates on your conversations with Arlo and with ST technical support. I’m leaning towards purchasing the 5000 hub from Amazon. Happy Thanksgiving.
Rob,
Thanks for the continuous updates, they are helpful. I use the VMB4000r and have the same problems. I just wondered if the same issues arise with different versions of ST. My ST hub is a generation 2 using firmware 000.027.00009 and my ST app is version 2.18.0 (1448). I certainly hope (like everyone else) that a fix is produced soon.
So as i stated earlier I confirmed the that the VMB4540 hub that comes with the Pro3 and the new vmb4500 hubs seem to work fine with Smartthings. I have continued to use the Pro3 cameras with the VMB4540 hub since. I was intrigued with the issue you are having with activity areas as potentially pointing to a bigger issue with that feature. So i just tested my pro2 cameras on the VMB4000 hub without a activity area, and a pro2 attached to the VMB4540 hub. It worked fine with multiple activity zones
@Thyg0d wrote:
Arlo got bought by Verisure (at least in Europe)
Just to clarify that deal, I'm linking in the press release: https://www.arlo.com/en-us/about/press-releases/2019/Arlo-Verisure-Partnership.aspx
As a temporary workaround I purchased the Costco Black Friday Arlo Pro 2 three camera special with the older 3500 hub for $279. I needed a few extra cameras anyways. The 4000 hub that isn’t working with Smartthings is still hooked up with my non critical cameras and the 3500 hub is now hooked up with the critical security cameras that are triggered by Smartthings sensors. So I now have 2 hubs on my network. I did notice that the 3500 hub signal strength is lower than the 4000 but it seems to working ok.
I saw that the new 5000 hub is working good with Smartthings but I’m wondering if the Zigbee radio that is in the 5000 hub could be disabled so as not to interfere with the Zigbee radios in Smartthings and in the Hue hubs.
I don't blame you for being hesitant. The 4000 hub is not just having issues with smartthings, it will not accept a record trigger sent from IFTTT either. Support on this has been hopeless.
Like you, I am worried that any other hub can potentially have the same trouble in the not to distant future.
						Amazon Alexa111
						Apple HomeKit713
						Apple TV App7
						AppleTV31
						Arlo Mobile App60
						Arlo Pro2
						Arlo Pro 21
						Arlo Q (Plus)1
						Arlo Secure10
						Arlo Smart39
						Arlo Wire-Free1
						Before You Buy30
						Features86
						Firmware Release Notes8
						Google Assistant94
						IFTTT92
						IFTTT (If This Then That)117
						Installation90
						Modes and Rules13
						Motion Detection1
						Online and Mobile Apps70
						Samsung SmartThings82
						Security System1
						Service and Storage5
						SmartThings73
						Troubleshooting393
						Videos1
