Iftt chnnel
hi everyone,
i have set up iftt to trigger an event on motion, it seems ro work for about a day and then stops. i then need to disable and reenable the channel again for it to start workig..has anyoe else seen this issue?
D
danieledge,
This could be an issue with the recipe you are using. Which recipe is behaving this way?
Does Arlo still behave as expected even though the IFTTT recipe is not?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
