Hi there,
I own a Arlo set with 4 cameras and enjoy using it so far.
But is there any project for Arlo to support IFTTT in the future? For example it would be great to put or blink all lights red when Arlo detects motion. Or to tell Amazon Echo : "Alexa, put Arlo all motion ON."
This feature will add Arlo great deal of more function.
Thanks,
Cihan
Hi Cenk,
I believe your concern is similar to what has been posted several times as feature request on the Arlo Idea Exchange site. Kindly check it here. You may comment on the posts. Otherwise, you may create your own post in the Arlo Idea Exchange site and state the feature request you want then give a kudos to it. The more kudos, the more attention it gets and the more it might be possibly implemented.
Cheers,
DaneA
Netgear Community Team
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
