- English
- Arlo Forum Discussions
- Partner Integrations
- IFTTT recordings show up in the Library as Motion ...
IFTTT recordings show up in the Library as Motion recordings.
I have made a few IFTTT triggers to record for 10 seconds. I expected them to show up in the Library tagged as "IFTTT". However, they are tagged in the Library as Motion triggered recordings. I don't have anything tagged as IFTTT. First i made 2 separate triggers (1 for each camera) to record once an hour for 10 seconds. Then i deleted both of them and made just 1 trigger to record once a day. All of these IFTTT recordings show up as "Motion". Since there is a tag labelled "IFTTT", i assume that someone thought that the video's would be properly tagged. Is this a work-in-progress? Or is there something i can do to make these be properly tagged?
Thank you
brian82,
I will escalate this question for further clarification and post an update once I have more information.
I got an email asking if this solved my problem. No, it didn't, but, thank you for looking into it! Let us know what you figure out, thanks
AppleTV
32 -
Samsung SmartThings
84 -
Security System
