Homekit
  • 5 Replies
  • 2579 Views
Christer_L
Hi.
Same as many others. Can't get HomeKit to work with my system!
Token??
5 REPLIES 5
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
danhan1
Hello. Can you reset mine as well? Do you need any info to do that? Thanks
danhan1,
Christer_L
Hi... Worked perfectly...... Until... Smart hub lost connection and then it is impossible to reconnect to HomeKit.
Do you know why?? I hoped this was a permanent solution. Tried to reboot Arlo Smart Hub, didn't help! A new Token??
Best Regards!
Chris
Christer_L,
