- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Homekit screen not showing base station (VMB40...
I have:
- 1 VMB4000(r3) Arlo Pro base station, firmware version: 1.14.1.1_2913_78b189a
- 4 Arlo Pro (H11) camera's, firmware version: 1.092.0.23_32920
My iPhone is at iOS13.1 (Beta).
In iOS settings I've configured Arlo to have access to Home Data.
When I go to Settings inside the new Arlo App, My Devices, Basestation, HomeKit Configure, nothing shows up, see screenshot (it's in Dutch but it just says it's searching). It can go on and on spinning without any results.
Does any of you have an idea how I can get them shown and added?
Thanks!
Ok, I seem to have solved it, for those interested.
My Arlo Basestation was directly (through network cable) connected to my Router. But I have a Google Home connected to my Router also which I use for the WiFi, so on all my mobile devices I'm on the Google Home WiFi network. However Arlo or Apple Home then doesn't recognise that I'm on the same network as the Arlo Base station. What I did was temporarily enable the WiFi on the router itself, connect to that, and then I was able to configure the camera's in HomeKit inside the Arlo App. I now have turned off the Router WiFi network again and it still seems to be working.
AppleTV
31 -
Samsung SmartThings
82 -
Security System
