HomeKit token reset
I had to remove the integration with my home to troubleshoot an issue. I now cannot see the device when I try to enable HomeKit. I think a token reset is the solution. Thoughts?
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
If you see library:
How do I connect my Arlo device to Apple HomeKit?
If you see feed:
https://kb.arlo.com/000063184
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
