- English
- Arlo Forum Discussions
- Partner Integrations
- Have a simple "If motion is detected, then trigger...
Have a simple "If motion is detected, then trigger XX" light for IFTTT but not working
Greetings,
Does anyone else seem to be having issues with IFTTT Arlo applets recently? I have a simple "if motion is detected", "then trigger XX light". Worked flawlessly for some time, now recently not firing? I've rewritten/reapplied it a number of times, patiently waited for it to stick, etc... No luck. Is it just me? Thanks for any feedback....
Hey MadDasher,
I would suggest to the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
AppleTV
31 -
Samsung SmartThings
82 -
Security System
