- English
- Arlo Forum Discussions
- Partner Integrations
- Have HomeKit set up. When adding second Base Stati...
I have set up HomeKit and it works perfectly with one base station and all the cameras associated with that base station.
When I try to add a second base station, I can do easily however whichever device I use to set up the second base station (iPhone or iPad), goes crazy and out of sync with everything else..?
Anyone else experienced this..? Anyone added more than one base station successfully..?
Help appreciated.
Hello. Thanks for replying.
What I meant was... when I set up Arlo in Apple Home with one base station, all my apple devices were in sync. When I added my second base station to Apple Home, whichever device I added Arlo with (iPhone for example) had the second base station (and associated cameras) showing, but no other Apple device did. Then when I added a new accessory via another device (iPad for example) then the device I used to add the second Arlo base station (iPhone in this example) would not sync.
Anyway... after many attempts and re-setting sessions, they now all finally work. I'm sure this was not a user error on my part, maybe a software glitch. All good now so thanks anyway.
Hi mdbridgens,
Could you clarify what you mean when your second Base Station goes crazy or out of sync? Do you mean anything on the second Base Station goes offline?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
