HELP Token reset Homekit
From reading other posts I believe I need token reset on my base VMB4000r3 station in order to successfully connect to Apple HomeKit.
serial #
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:
How do I connect my Arlo device to Apple HomeKit?
Thank you it worked!
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
