Google Home Integration Improvements
  • 4 Replies
  • 351 Views
TheFloridaB
Is there any plan to expose sensors to google home? Im trying to easily have ways to determine which sensor is triggered without my phone (such as having google announce it via a google home hub using automations) the chime is nice but it greatly lacks customization
ShayneS
HI @TheFloridaB
Thank you for your feedback. While I'm aware that the sensors are accessible through the Google Home app, I don't believe this type of automation is currently supported. I've shared your feedback with the appropriate team and will provide any additional information if it becomes available.
ShayneS
Hi @TheFloridaB
I received some feedback from the team regarding this. Can you try these steps and see how it goes?
Want Google Home or Nest Hub to announce when a specific Arlo sensor is triggered like "The Front Door is Open"  instead of just a generic chime? You can set this up with a Google Home Automation.
Before you start: Make sure your Arlo account is linked to Google Home, so your Arlo sensors appear as devices in the Google Home app.
Steps:
  1. Open the Google Home app.
  2. Go to the Automations tab.
  3. Tap Create Automation (the + icon).
  4. Under Starter, select your Arlo sensor and choose the state you want to trigger the automation (e.g., Open/Close).
  5. Under Action, choose Broadcast.
  6. Enter your custom Broadcast Title — this is the message that will be announced (e.g., "Front Door Open").
  7. Give your automation a name, then tap Save.
Now, whenever that sensor is triggered (for example, when the front door opens), every Google Home speaker and Nest Hub in your home should announce your custom message out loud.
TheFloridaB
Hi!
I did try that. But no matter how many times i disconnected or reconnected my account or the devices, the sensors wouldn't even show up in automations.
ShayneS
Thanks for the update, Let me inquire with the team and I'll report back as soon as possible.
