Geofencing issue solved with work around
I have found that using a combination of IFTTT and the Life360 app is far more reliable than using the geofencing in the ARLO app. Setup family members on the Life360 app and create a recipe for home and away. Has worked without fault so far.
I have also been able to setup OK Google voice commands to toggle the arm/ disarm function via IFTTT and gmail channel
that sounds cool! My family uses Life360, and i would love to set that up.
Can you explain what you did, how you did it? Or point me to some instructions?
THANKS!
If you download the ifttt DO button you can also put an arm/disarm buttons on your home screen, saves having to go through the process of logging in to change the mode of arlo
Please can you tell me what settings you use in the Arlo app itself.
thanks in advance
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
