Does the Arlo Pro work with the new Google Hub?
  • 4 Replies
  • 7156 Views
gserle
Does the Arlo Pro work with the new Google Hub? Can you display your camera views using Google Assistant on the Google Hub just like with the Nest cameras?
JessicaP
Hi @gserle,
You can view the Arlo Pro with your Google Home Hub. I am able to use mine to view the Arlo Pro camera.
ngdlite
what did you say to have it displayed? Mine keeps saying “I can’t help with that”
JessicaP
Hey @ngdlite,
What you can do is swipe down on your Google Home Hub and tap on camera. Then you should see a list of cameras, including Arlo cameras, to view the stream. Make sure your cameras are connected to the same WiFi network as your Google Home Hub.
gserle
Thank you! I purchased a Google Hub on Thursday and I was able to get my camera to display on the screen. The great thing about it is that I was able to use away from home as long as I had wifi access
