- 2
Does the new Pro 3 work with Smartthings, more specifically video integration? One of my biggest disappointments with the Ultra is neglecting Smartthings and taking away my ability to view my cameras in a centralized location and integrating them into rules for automation.
For Pro 3 cameras there is no way to interact with them from Smartthings. Arlo hasn't added the Pro3, ultra, either doorbells to the integration yet. Until they do that Smartthings is completely unaware of them.
It’s a goal of Arlo’s to make as many cameras compatible with these integrations as we can but we don’t have an announcement to make regarding Arlo Pro 3 compatibility with SmartThings at this time.
Thanks for the response. Does Arlo realize they are loosing fairly a large base of integrators that had worked with your cameras in the past, we are having to recommend other cameras moving forward.
Shawn
It’s pretty obvious that Arlo has no intention of integrating their products with SmartThings moving forward. After a substantial investment in Arlo products I’ve had to move on to other options for my customers.
There are also options like using RSTP cameras with Blue iris as a NVR. This just takes you down a much more involved path as you would be managing your own infrastructure to run it. It is a big difference from a Arlo setup, and honestly I wouldn't expect most here to want to go that route. Would be much better video quality though as the video wouldn't be over compressed like arlo does.
I've had an Arlo system integrated with Smartthings for a few months and have been fairly happy with it. Had an opportunity to purchase a Pro 3 add-on camera fairly cheap, so I did. Got it added to the Arlo base station with no problem, and just discovered that it won't connect to Smartthings.
What a joke. Keeping Arlo and paying for a monthly cloud service charge is becoming less and less attractive. After many many issues with Arlo geofencing, and now this, it makes me wonder if Arlo will ever become a stable, viable solution, or if its just an expensive overrated toy.
Amazon.co.uk are selling these (in fact, all Arlo cameras) with an image of a feature comparison chart. Every camera on that chart is alleged to be compatible with SmartThings. I bought the Pro 3 2-pack on that basis and now find that the cameras aren't compatible with SmartThings after all.
Sample link: https://www.amazon.co.uk/Arlo-Security-Rechargeable-Spotlight-VMS4240P/dp/B07XZQM4WK/ref=sr_1_6?crid...
Seems like a good way to escalate the issue and bring it to the attention of the decision-makers. 👍
I hacked a solution using IFTTT. I had an unused SmartThings Switch which I repurposed as a sort of state manager for this solution. (I don't use it to actually turn anything on or off). I use SmartThings automations to turn that switch on or off based on presence or manual arming/disarming.
So SmartThings Armed = Switch On. You get the idea..
Then on IFTTT I have have 2 triggers which set Arlo arming according to the state of that switch.
So basically the switch just acts as a boolean that both systems can utilize.
So when is the time when it will be supported? This is ridiculous... PLEASE fix this asap.
This response is useless. At least provide us information on if it is on the roadmap or not so that we can return our Arlo products and purchase products that support our integrations.
On the Smartthings Community website there are several posts about a new schema that supports all Arlo cameras, I believe. The schema is already available but is still a work in progress. Smartthings and Arlo engineers are working together to make this work smoothly and also to address some of the issues and customer requests that have arisen.
BRH
I posted this in another thread but now that this one moved up here is a link to the Samsung Smartthings community forum on this.
https://community.smartthings.com/t/new-smartthings-schema-integration-for-arlo/210605
- 2
AppleTV
21 -
Samsung SmartThings
59 -
Security System
