Conexión Arlo Pro y Alexa
Buenos días. Tengo un kit arlo pro VMB4000r3 con 4 cámaras H8 y recientemente compré un Alexa Echo Show y no estoy pudiendo agregar el skill para poder manejar a traves de Alexa las cámaras.
Encontré esto: https://kb.arlo.com/000044726/How-can-I-pair-my-Arlo-cameras-with-Amazon-Alexa?_ga=2.207696411.80905... , pero en el listado de equipos compatibles no figura VMB4000. Esto significa que no voy a poder conectar mi sistema Arlo a Alexa?
Gracias
The article is listing cameras, etc - no base stations are included. It lists both the Pro (VMC4030) and the Pro 2 (VMC4030P), so it should work for you.
What you are actually doing is connecting your Arlo account to Alexa.
Thank you! My Arlo Pro base station is VMB4000. Sorry but I don’t understand what i should do to connect Arlo with Alexa.
That doesn't matter for this. Do you see "Library" in your app menu? Or do you see "Feed"
and "Dashboard" instead?
If you see "Feed" then follow the instructions that lead you to the "Connected account" here:
If you see "Library", then follow the instructions at the end of the article.
AppleTV
29 -
Samsung SmartThings
78 -
Security System
