- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Can’t record and stream to Echo show at same t...
Like several other posts, I had a problem with showing my doorbell camera only when triggered by an Alexa routine. My Echo Show will show the camera with a voice request no problem and the routine will work when manually played. However, it does not work when there was an actual trigger(motion in my case). Alexa says Doorbell is not responding. I finally figured out that the problem is that I also record motion through the Arlo app. It seems like it can’t access the camera stream when the doorbell is recording or even when just streaming live in the Arlo app. I now have to choose between recording the event and being able to show the camera on the Echo show. Seems like a real deficiency with the doorbell. Will this ever be supported? Do other doorbell cameras support more than one operation at the same time?
Hi @etsuch99
What you are experiencing is by design. This device doesn't not support dual streaming. You have the option to choose to show on the Alexa show or record video.
Hi @etsuch99
Thanks for the feedback, let me look in to this to see what I can find out. I will report back as soon as I have more info.
The Arlo development team is currently investigating reports of this behavior. We will provide an update as soon as we have more information to share with the community.
Hi @etsuch99
AppleTV
32 -
Samsung SmartThings
84 -
Security System
