Arming/Disarming Arlo Pro4 with Alexa
Does Alexa’s Arlo skill not support arming or disarming Arlo Pro4 cameras? There is no base station or hub since the Arlo pro4 connects via WiFi. Cannot seem the get Alexa to arm or disarm - says it doesn’t support that. Pls provide any insight you may have on how to get this to work.
The commands you can use Alexa for are listed within the KB below. However, arm and disarm is not something that is supported.
https://kb.arlo.com/000044725/What-Alexa-commands-can-I-use-with-the-Amazon-Echo-Show-to-view-my-Arl...
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
