Arlo Ultra and Arlo Audio Doorbell
Hi,
Is it possible to connect Arlo Audio Doorbell and Arlo Ultra to Alexa so the Alexa shows the view from the camera when the doorbell is pressed? Or it is needed to say the commend "show the camera XXX" every time when Alexa alerts that the doorbell was pressed? Also, is the option to talk through the audio doorbell using Alexa is possible? Or it's only for Ultra?
Thank you.
Thank you.
Hi @albulance
Please contact the Support Team to further look in to this inquiry regarding Alexa & your Arlo Ultra/Audio Doorbell. You will find several options for contacting support in the provided link. Arlo Tech Support
AppleTV
28 -
Samsung SmartThings
76 -
Security System
