Much like many other users on this forum, I'm not getting audio via HomeKit when not connected to home wifi network.
When I'm on my local wifi network, Everything works fine. The issue happens only when I disconnect from my local wifi and use the cellular data network.
Video and Audio works fine on both Local Wifi and Cellular on Arlo App
Video and Audio works fine if streamed by HomeKit when I'm on my local Network
Video Works fine on HomeKit if streamed on (5G) cellular
Audio doesn't work when streamed via HomeKit on (5G) cellular
I have removed the Arlo's from HomeKit and reinstalled them.
Arlo Bridge = VMB 5000 AU
My home internet connection is getting >100mbit down and 20mbit up
Hi RhysL,
Have you tried rebooting your iOS device to see if that may help? Also make sure that you're on the latest iOS version.
Yes I have, Also, This is happening on multiple devices.
I have seen many people here posting about the same issues but you always seem to advise people to use private messages to solve the issue so the solution is never posted.
This is clearly a known issue. What have you been doing with other people to solve it?
I would suggest contacting the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
AppleTV
31 -
Samsung SmartThings
81 -
Security System
