Arlo Pro 2 "crashing" Nest Hub 2
I recently got a Nest Hub 2 and tried the Arlo Integration. While it works fine, for some unknown reason, after streaming the cameras to the hub, Im unable to cast to the hub from any other video app. (Netflix, YouTube, etc.) Is this a known issue with the Arlo and Google Assistant Integration? Is someone else in the community experiencing something similar?
Please contact the customer support team to look into this issue you are reporting. Arlo Tech Support
All right, I'll follow up with them. Thanks
AppleTV
31 -
Samsung SmartThings
81 -
Security System
