  • 7 Replies
  • 2890 Views
  • 2 Likes
Sbrass
Hello. I have a VBM4000r3 (all firmware up to date) connected via ethernet to my Orbi RBR50 Mesh system (also up to date, ) and I'm trying to set up Homekit. The Arlo app is unable to discover my base station - and I have tried on both my main Orbi and a satellite. I have restarted the Also Base station several times as well, but I haven't restored the Arlo to factory settings just yet.
Reading other posts the issue is either (1) I need a token (if so, please send!) or (2) due to the orbi I don't have my Arlo basestation and my phone on the same wifi network (if so, what is the workaround - I don't see anything in the Arlo app or website that allows me to select a wifi connection.
Thanks!
ShayneS
Thank you
7 REPLIES 7
Sorry, this isn't very clear.
Are the base and cameras online (forgetting about homekit)?  If they are, you need a token reset.  Just wait for the mods to get to it.  When they tell you it's been reset, then restart the base and try homekit again.
If you've removed the base/cameras from your account, and can't onboard them again; or if they are otherwise offline: Then you have a very different issue, and you should forget about homekit until you get things back on line.
Sbrass
Sorry it was unclear!  Yes the base and cameras are online. Everything is functioning individually as needed - I just can't get the Arlo app/iphone to discover the Arlo base station. All of the articles I read didn't make it clear how to approach when the Arlo system is getting internet via an ethernet connected to a Mesh system and therefore the arlo and iphone won't be on the same wifi network.
"Online" means the cameras are onboarded to the account, and that you can livestream the cameras from the app or my.arlo.com.  Are you saying that that is working?
Sbrass
Correct!
Correct!
Ok, then the base is also on-line.  It sounds like the issue is that you cannot connect the base to homekit.
If that is the case, then you need token reset.  The mods ( @JamesC and @ShayneS ) can take care of that for you.
ShayneS
Thank you
Sbrass
That did it!
