- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Arlo Cameras works with Amazon Fire TV when li...
- 2
Arlo Cameras works with Amazon Fire TV - Follow the steps below:
Enable the Arlo skill for your Amazon Echo
Link your Amazon Echo to your Amazon Fire TV under Movies, Video & Books
Select Fire TV
Then say Alexa show (use your camera name) it takes about 30 seconds to show on your TV.
Enjoy your Camera view on the big screen and use Amazon Echo for hands free control of your TV!☺
Thx
thanks for the tip
this does indeed work. There is a 5-7 second lag between the TV and the camera.
It can take some time to connect which I'm still trying to figure out. But still useful.
I've tried all the above linking, phrases, etc and every time, Alexa responds to my query with 'I couldn't find a camera in that group'. Has anyone else had this? Google came up with nothing! I get this response for requests on all of my cameras. My Pro/Pro 2 cameras are 'grouped' to the base station but I have a Q Plus that's not in a group and it says the same for that. I don't know what to try.
I've tried just using a Fire TV Stick (2nd gen) and via an Echo.
Try to disable the Alexa skill and re-enable it and see if that resolves the issue. You can read more here on how to use your Amazon devices with your Arlo Cameras: How can I use Amazon devices with my Arlo cameras?
The extra step needed I found after enabling the arlo app is to navigate to Smart Home > add a device (+ symbol top right) > Add Device > Scroll Down to Camera > Netgear Arlo and tap on DISCOVER DEVICES at the bottom. Let the app sniff out your cameras on your network, then the cameras will work. This worked on my Firesitck Gen2 linked to Echo dot, did not work on Gen1 firestick.
Do you need the Echo? According to Amazon's website, you need one of the following and the cameras:
FireTV any generation
Fire Stick 2nd gen or newer
Echo Show
No need for the Echo. You need to have the Alexa App installed on your phone or tablet, that's how you discover the cameras on your network. I couldn't get the first generation Firestick to work with my Arlo Pro2 cams the app told me it wasn't supported..
- 2
AppleTV
Samsung SmartThings
79 -
Security System
