Apple TV streaming
All my cameras Ultra 2 / Door Bell / Flood Light will activate with motion thru my APPLE TV (Home App) onto my TV. (Small/split screen view in top right hand corner). The problem is, the live view stream doesn’t flow thru. What shows up is a black/grey screen with date stating the last time it flowed thru successfully ie 6 days ago…
If I reset HomeKit in Apple TV, it may work once, but then next time, the same issue occurs.
I have no issues with Arlo cameras with any other HomeKit app/device.
Hooka72,
You should be able to stream using apple tv, see here for more information: https://kb.arlo.com/000062508/Can-I-live-stream-my-Arlo-camera-on-Apple-TV
Do you experience any issues streaming the cameras using the Arlo Secure mobile app? Doe the signal strength show strong for the cameras?
Thanks James, no issues using the arlo App.
I have a feeling it is maybe when the cameras are disarmed due to scheduling mode?. Strange though that movement detection will still be active when the camera is disarmed.
Thoughts?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
