Apple HomeKit token reset
  • 16 Replies
  • 6957 Views
  • 6 In Conversation
m1jacob
Can I get a token reset for apple HomeKit please?  Thanks.
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
16 REPLIES 16
m1jacob
That got it. Thanks. Much appreciated.
Mul51
Hi
if possible could you send a token reset to my account please.
basestation VMB4000r3
Thanks in advance
Peter
ShayneS
Hi @Mul51
Can you bring your base station online and I can reset the token.
N124
Can i get a apple homekit token reset? Base station asks for qr code upon installation
ShayneS
Thank you
N124
It’s still asking me for apple homekit QR code after reboot. My device never came with that code
ShayneS
@N124
Can you try removing and re-adding the Arlo app.
N124
I removed it but no change. Still asking for apple homekit qr or set up code
ShayneS
I reset all your device's HomeKit tokens, go ahead and reboot your base station and try again. You can try removing th app agin if you like as well. if this doesn't't resolve the issue, we may need to do a factory reset on your base station.
N124
I removed it and added it back.  I also held down the reset button, but no change.  Still asks for apple HomeKit QR code.   Do any of the hubs actually come with a code?
ShayneS
@N124
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
N124
Yes I contacted them but they have no solution
ShayneS
@N124
I'll escalate this for you, the escalation number is: 43254827
Someone from the escalations team will be reaching out soon.
anothersteve
Hi can I also get a reset token for my base station please? I can’t get HomeKit to see it.
@JamesC
ShayneS
@anothersteve
Thank you
