- English
- Arlo Forum Discussions
- Partner Integrations
- Apple HomeKit stuck at "Discovering your device. P...
Apple HomeKit stuck at "Discovering your device. Please wait
I've seen some responses about needing a token sent for this issue?
Also having this issue, could I get a token reset? Thank you
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Can I get a token sent as well? Thanks
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
Can I please have a token sent as well?
Can I have a token sent? Thanks
Could I get a token reset to please
I need a token reset please
I also can Not add base Station and Camera to HomeKit.
reset and multiple re-Installationsmdid Not Work out.
can you send a reset Token?
many thanks
So I need to remove the base and therefore setup the base and re-install all the cameras again? Or is a restart of the base sufficient?
Restarting the base is sufficient.
Same issue. How do I get this token reset? Thank you.
I’m having the same issue, are you able to issue a token to me?
Danlfc72,
Hi,
I also need a token reset. I used to get notification via my Apple TV and view my cameras. No longer can see cameras on Homekit....
Please assist with a reset.
Thanks,
Chuck-cheese_08,
I need a token reset also.
Need a token refresh please. Thank you
AppleTV
31 -
Samsung SmartThings
81 -
Security System
