- English
- Arlo Forum Discussions
- Partner Integrations
- Apple HomeKit stuck at "Discovering your device. P...
Apple HomeKit stuck at "Discovering your device. Please wait."
I had HomeKit set up but then removed it because I was reorganizing things. Now when I try to add my base station again the app just gets stuck on "Discovering your device. Please wait." I saw this posted elsewhere for a different hub and support sent a token reset request which seemed to resolve the issue for others. Is that what I need here?
Hi Casaflyr,
Let me reach out to you via private message to gather some information from you.
Hi Flerric,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
App is stuck at “discovering your device. Please wait” while trying to setup HomeKit.
Please send reset token.
Model - VMB4000
Firmware - 1.16.5.0
IOS 14.4
Hi David_2021,
I’m having exactly the same issue regarding my HomeKit integration.
At first it was working fine but since several months it is stuck on “searching for a device. Please wait.”
May you help me to solve the problem?
Thank you
Hi luigijj,
My HomeKit integration has been working for around a year, no problem.
Then yesterday all cameras stopped responding in HomeKit, fine in the Arlo app, just not HomeKit. I fiddled, rebooted etc, nothing, no video.
So as a last resort I removed the Arlo hub from my HomeKit home, went to add it again and I am stuck with the endless discovering problem!
sTeVE
I’ve seen similar posts where a rep sends a new “token”. Was wondering if someone could help me out.
Thank you
Hi Jetbootjack, Epor, Beauseph,
Thanks JessicaP, that worked a treat!
sTeVE
Hi! I’m having the same issue, would love to get a reset token if possible.
Hi Sebaszs,
Hi mbphx,
Thanks so much
trying to connect to HomeKit. I was once connected but after some issues I tried to reconnect and cannot. I’ve read others having this same issue and you would send them a token reset to the base and it would solve the issue.
Apparently, I'm having the same issue. Could you please send the same reset request to my device. Thanks.
Hi Kayfabe1999, tgabtg, aarondy90, formsguy, Branmac, jj104,
I've sent a token reset request to your Base Station/SmartHub that should resolve the issue. Please reboot your Base Station/SmartHub (remove and reapply power) allow the Base Station/SmartHub to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
I'm also unable to pair my camera 1 camera to the hub, would the reset token help my case?
Hi DoraAzuli,
Can the arlo pro 2 even get HomeKit support? If so , do I have to totally reset my entire system?
AppleTV
32 -
Samsung SmartThings
84 -
Security System
