  • 1 Reply
  • 721 Views
RICKMILLS
3 OF MY CAMERAS ARE TURNED ON FOR MOTION. THE 4TH DOES NOT DETECT MOTION. HOW DO I GET IT TURNED ON?
You'll have to check the ARMED mode to make sure it's included and set for motion correctly. ( assuming your turning on all the other cameras with the default ARMED mode )
goto MODE > click on edit pencil in ARMED
Pick the camera if listed thats not working and hit EDIT
( if that camera isn't listed you can add it back in )
Make sure the box is checked for MOTION and RECORD, also use the edit under each for sensivtivity and duration of record
HIT SAVE ON WAY OUT
