manual says i can monitor my cloud storage where is the option in app?
  • 1 Reply
  • 858 Views
Harryinny
The manual shows options for making the cloud storage tell you if its full, you can tell the system what to do if its full. I see no options at all about settings for monitoring the storage, how much you have left, what to set the system for when the storage is full(as per the manual). I see nothing. I mean when you have only 1gb of storage, it would be nice to know what it left. The manual says you can set these things up yet i have no options.
Thanks for any help.
Harry
Schorschi
Prodigy
Prodigy
The manual is outdated.
There is no longer a storage limitation.
Your only limitation is set by your subscription plan, keeping a rolling history of video clips of the past 7 (basic plan), 30 (Premier plan) or 60 days (Elite plan). The basic plan is the only free subscription option.
