iOS App "Timeline" settings
  • 2756 Views
jw154j
On the iPhone settings menu under the Arlo app there are settings that are not described in any document that I've found.
User Name: _____
Password: _____
Download to: Arlo
Timeline nDVR: on/off  (default ON)
Timeline ffmpeg: on/off  (default OFF)
What effects do the "Timeline" options have on the performace, quality, and/or compatibility of the Arlo system?
jw154j,
I apologize if this caused confusion. This was a bug that was fixed with the 1.8.5 release of the Arlo iOS app. I recommend that you upgrade your Arlo app to the latest version.
jw154j,
Hdg
The 'Download to Arlo' option still exists. Please explain?
it use to be the FOLDER name in the gallery on the ipad that the d/ls would go to... ( still prob is )
