activate one camera
  • 1 Reply
  • 2291 Views
Hemphill
I have 4 cameras, is there a way to only activate one or two cameras at a time.
Assuming you mean recording on only one or two cameras as opposed to connecting them to the base station in the first place, the answer is yes - it's how you set up rules, modes and schedules.  Have you looked in Settings near the top left for them?  Set rules first (select only the cameras you want), save, go to Modes just above Rules and assign the rule(s) to modes and save.  Finally, go to Mode (bottom of screen) and either select the mode you want active of enable schedule and place the mode(s) as you desire by dragging and dropping. Start at the beginning of the day and add modes under it.  Change the times by grabbing the bars and moving up or down.
Works best in a browser.
