VMB3000 Not Saving Email Address
  • 6 Replies
  • 2500 Views
  • 3 Likes
JonInSJ
I am trying to enter in an email address in a rule in order to get a notification, and the email address is not being saved.
I click on "edit" to edit the rule. I scroll down to the bottom and click on the box next to "send email alert."
Then I enter a valid email address in the email field.
I'm clicking the save button after entering the email address.
But when I go back into the rule, the email field is blank.
Any help would be appreciated.
Thanks.
Jon
I suspect the problem is that you're not clicking on the "+" to the left of the address field after entering the address and getting the green checkmark. Without that, it won't show up in the To: line just above the entry box.
6 REPLIES 6
After entering the email address, Are you seeing a green check mark at the end showing it's a valid email address ??
( before saving )
JonInSJ
Thanks for the quick reply.
Yep. There is a green checkmark at the end of the field when I finish entering the email address.
Try a power button reboot of the base, give it a min or tow to come back online... then try the email again and SAVE.
it is strange.
JonInSJ
Hi. I tried a re-boot of the system.
Nope, it didn't work. It still won't save the email.
Yes, I agree. It is strange.
JonInSJ
Yep. You got it. I was not clicking the "+" sign. I was only hitting the "save" button, thinking that was enough.
I have clicked the "+" sign, and now everything is saved.
Thanks for the help!!
Jon
